rahalim007 0 Report post Posted December 12, 2006 (edited) I have 2 laptops running Win-XP Pro and need to make them connect using CDMA USB Modem directly (not using VPN). How to establish the direct data call (create, answer and hangup/disconnect) using AT command? I can't find any complete reference for using the AT$QCMTOM command, could anyone help me please... PS: I have no problem when connecting them using PSTN modem (RAS with Dial-up Connection and Incoming Connection method). Edited December 14, 2006 by rahalim007 Share this post Link to post Share on other sites
manubatham2006 0 Report post Posted August 12, 2007 I don't know how. But it will very costly to u if u connect two laptops through mobile to mobile data call. It means at least 30 paisa on tarrif. Share this post Link to post Share on other sites
Genius 817 Report post Posted August 12, 2007 rahalim007 said: I have 2 laptops running Win-XP Pro and need to make them connect using CDMA USB Modem directly (not using VPN).How to establish the direct data call (create, answer and hangup/disconnect) using AT command? I can't find any complete reference for using the AT$QCMTOM command, could anyone help me please... PS: I have no problem when connecting them using PSTN modem (RAS with Dial-up Connection and Incoming Connection method). I my opinion connect to net and use Yahoo or Net Conference IM as they have better voice compression. try it out Share this post Link to post Share on other sites
ksudeep 0 Report post Posted August 31, 2007 hi, you can even try with the softwares like GoToMyPC. google it. i use TeamViewer (www.teamviewer.com) excellent software. free and lightweight. both desktop sharing mode and file transfer mode are available. Share this post Link to post Share on other sites
kshah 452 Report post Posted September 1, 2007 Data call between two mobile will not be possible as it is blocked at switch level. That is the reason why fax is not supported even on FWT / FWP which are supposed to be replace wired fixed lines. WLL was initially developed for that only. I have tried this in past (When reliance was launched). that time CC was very helpful because they had very few customers. Share this post Link to post Share on other sites
