kornograf
Reliance Usb Huwaei Card
Hi, I just got the Reliance NetConnect card (Huwaei) and it was working fine for a week. However, since last night i am unable to connect and the error message i get is 'The Remote computer did not respond. For further assistance click Search Help and Support...'
What does this mean? There is also no error number for this.
Can someone please help me with this?
check control panel> network connections.
may be is it disabled
@kornograf
My dear friend try installing drivers again. First delete your modem and again install it. May be your problem got solved.
At times I also get the same message while trying to connect thru my lg cordless,I just turn off the phone and switch it on after 5-10 mins.To my knowledge its a network problem if your connection is active from their end.
Also lately from the past few days I have been facing a lot of network problem in Mira road,my phone shows full network but when I dial my own no from any other phone it shows as not reachable.
Dont know whats going on.
Anyone else in mumbai or close to me facing same problem please share.
@prathod
My dear friend in which area of Mira Road you are located ?
@Honest.
I am located in Sheetal Nagar,next building to Mtnl Exchange.
Are you familiar with Mira road ?
Ya my dear friend I am very much familiar with Mira Road. But I don't think there is a problem in your area. Whenever I visit Sheetal Nagar, I never get network problem. So check your handset.
By the way, now are you getting Star One by your cable operator or not ?
Edited by Honest
I have got 4 connections altogether and all of them cant have problems at the same time.
I first had the same notion and changed my mobile but still the problem is there
And why did you ask about star one :Contento: ,yes we do get star one.
Btw where are you located and where in mira road do you come.
My dear Prathod. As I am aware MTNL is located on the main road of Sheetal Nagar. So your society also must be located at the main road. I don't think in your area there is any problems. One of my friend is located at Happy Home Complex and he doesn't have any problems there.
And about Star One, you told somewhere in your post that your cable operator was not relaying Star One. That's why I just asked if by now you are get this channel or not.
By the way, what happened to yours and your friends 5 mobiles which were held up by Mira-Bhayander Octroi officials ? :Contento:
i think we know each other,you have got a whole lot of info about me.
Come out now,pm me,or else the mods and admins are going to ban us for wasting the forum space for chatting.
