aftabdarogar 0 Report post Posted December 20, 2006 I connect from my RD2030 handset using a serial data cable frpm my pc and its working gr8. i recently bought a campaq presario V5000 laptop as well as n lg ez sync usb data cable for my handset whenever i try to connect thru that the laptop hangs after 2 minutes and the connection goes into dormancy is there a problem with the usb cable? or my laptop? Share this post Link to post Share on other sites
Greens 21 Report post Posted December 20, 2006 Most probably the problem should be with your laptop.... Reload the OS... or else install a good antivirus software. Share this post Link to post Share on other sites
