Lakshmi
Any way to increase Messages Inbox space ?
Hiii..
does any of u hav got anyyyy solution to increase the inbox space ?? i can store only abt 110 msgs.. which is pretty sad..
anything related to this will be a help..
thanks..
none as of now.
well not as of nw...i just deleted templates to increase the space...
Hiii..
thanks..
i dont know :confused: if the handset has a dynamic memory and if it has :smile: then you can do it but then got to contact the service center.. :wink: . btw what is the use of the message if you have read it and done with it. sorry.. no offences ment. :smile:
one more thing you can do is if you are forwarding a message and want to preserve it too then you can save in sent and delete from Inbox as you will increase the number of messages.. unique messages in your Inbox.
i used to save it four ways i.e. archive, inbox, and drafts n templtes ( not in my current handset though!) :clap:
Our Dear Ashoksoft has done it in Log2030........ :cool:
I think he may be able to help us ????????
Ashok any solutions for 6265... to increase the message space ??????????
