vikrammundra
Chinese Charecters In Track List 6265
Need some help on this. Wonder if anybody else has faced this problem.......
On transferring songs to 6265, names of many songs appear as chinese charecters ( when viewed in Track List ).
When viewed throught gallery - appears in normal English.
Got no help from Nokia centre.
I had faced the same problem.... i think its an issue with some versions of the PC suite. Try upgrading to the new version and it will be resolved
  vikrammundra said:
I am using the latest version .... but still the same problem
Thel atest version is 6.82.22.0 if you have this one then try uninstalling it and then re installing. it worked for me.
  vikrammundra said:
Its the same even if I transfer mp3's directly, direct through file manager ( using blue soliel ) , without using PC Suite
Please delete all the songs that you have converted to aac or m4a format using the old version and re rip them....it should work.
