RAJJUMOTE 0 Report post Posted January 3, 2007 Hi friends. I am a student who need to download too much from internet. Should i go to freedom@night or not. What about bill? Share this post Link to post Share on other sites
Arun 795 Report post Posted January 3, 2007 If you have downloads during night time only, then Freedom@Night should be the best plan for you. If you use Net Connect during daytime, then the data plans (like Platinum) should be better though it is available only if you purchase the Data Card (not mobile). Share this post Link to post Share on other sites
Kunal Hemrajani 1 Report post Posted January 3, 2007 if u hve a BSNL connection(DOT)i tink the better option wud b..to go 4 BSNL broadband connection..(500 PLAN).. Share this post Link to post Share on other sites
supernova 47 Report post Posted January 3, 2007 there is also another option . swift 40 . rent 400 . total 40 hrs free in a month . divided into 20 hrs during day and 20 hrs during night . Share this post Link to post Share on other sites
Honest 836 Report post Posted January 3, 2007 (edited) My dear Rajjumote Before going for this plan, you must read the posts in these 2 threads also : Freedom@night = Boundation@day Should I go for freedom@night You will get better clarifications about this plan after reading both the threads. Regards. Edited January 3, 2007 by Honest Share this post Link to post Share on other sites
Sadikk 301 Report post Posted January 4, 2007 Will not suggest freedom @ night plan to anyone, it will keep u awake u all night, downloading in night on r-connect is not reliable as connection drops a lot and/or dormancy problems. Share this post Link to post Share on other sites
cracker 0 Report post Posted January 4, 2007 (edited) get data one and if u want unlimite wireless internet than go for airtel. if u have edge handset with class10 support and if edge is available in ur area than u may get download speed between 15-20KBPS kilo byte per second otherwise 5-6KBPS and yeah freedom @night s**ks for sure Edited January 4, 2007 by cracker Share this post Link to post Share on other sites
faiqg 0 Report post Posted January 8, 2007 and if u want unlimite wireless internet than go for airtel. Is there a provider other than Reliance NetConnect? Share this post Link to post Share on other sites
HetalDP 947 Report post Posted January 9, 2007 I dont Suggest any Mobile based Internet Plan Rather go for BSNL-250 It is the Best one. Buy Wireless router from BSNL in Rs. 1800 this can make Best Products I uses that for Browsing in PPC-6700 in Office and Home Only Some time use RConnect while Travelling and while i am on move Share this post Link to post Share on other sites
