snp_mg12 0 Report post Posted January 3, 2007 Hi..Frndzz......!! I really wanna know..that how speeds can b increased over Rconnect.?? N also. I want to downloads movies links other than rapidshare...!! Do help me out Frndz..! Bye..!! Share this post Link to post Share on other sites
Nirvana 4 Report post Posted January 3, 2007 One way is to ping to an IP when you are browsing, helps you keep your connection alive and speeds up a bit too. And check out this topic: http://www.rimweb.in/forums/index.php?showtopic=3353 Share this post Link to post Share on other sites
snp_mg12 0 Report post Posted January 3, 2007 One way is to ping to an IP when you are browsing, helps you keep your connection alive and speeds up a bit too. And check out this topic: http://www.rimweb.in/forums/index.php?showtopic=3353 But How to Ping yaar..?? Share this post Link to post Share on other sites
theking 35 Report post Posted January 3, 2007 go to start->run and type in:- ping www.google.com -t i.e. ping (site name) +t Share this post Link to post Share on other sites
Vijayan 0 Report post Posted January 5, 2007 One way is to ping to an IP when you are browsing, helps you keep your connection alive and speeds up a bit too. And check out this topic: http://www.rimweb.in/forums/index.php?showtopic=3353 USE THIS PING -- BEST.Performance Pinging available in http://software.ccschmidt.de DO NOT use google etc to ping to. Use Reliance servers itself--> click on net connect icon in desktop tray -->details-->server IP address.Give this address as host into Performance Pinging Share this post Link to post Share on other sites
cracker 0 Report post Posted January 6, 2007 but never ping rimweb.in it will bring down complete server Share this post Link to post Share on other sites
Saurav 22 Report post Posted January 7, 2007 if i ping will it increase data download speed from that site. Share this post Link to post Share on other sites
