neerajayshree
Netconnect Via Usb Wireless Modem
TOday i happened to go to the reliance communication website
and i found out an intresting thing they have introduced a usb wireless modem
might b good for people who have PC's(DESKTOPS) at two places
and Intrestingly this is available only in Tamilnadu
http://www.reliancecommunications.co.in/Co...ect_hotnew.html
First time in India a revolutionary product from Reliance Netconnect that lets you access the internet anytime anywhere. This product is a unique modem which can be attached to the USB port directly and helps you to do the internet, talk and send SMS.
Features:
Connectivity:
Wireless internet access across 5300 towns and 3 lakh villages.
Internet browsing and download speed upto 153.6 kbps.
Compatible with Windows 2000 and Windows XP.
Voice and SMS Compatible:
Make and receive voice calls
Send and receive SMS upto 1000 characters
Store 1000 contacts in your phone book
Specifications:
Item
Description
Protocol
CDMA2000 1X RTT
working frequency
824MHz ~ 849MHz/869MHz ~ 894MHz Uplink/Downlink
Dimensions
84 mm (D) x 42 mm (W) x 12 mm (H)
Weight
About 32 g
Receiver sensitivity
Better than -104dBm
Power consumption
≤1.5W
Power supply
5V/500ma, from USB
USB Card (EC325) has been available for months now, though it always has been in short supply. Its also available all over India. The line "Available only in Tamilnadu" is for the prepaid NetConnect cards.
reliance netconnect card is available for rs5000. what is the cost of this wireless modem. :P
usb card is now available for 4500
I got it for 4500 in Haryana
Yes my dear friends this USB card is available @ Rs. 4500/- at Web Worlds but Web World Express are selling it @ Rs. 4700/-.
I recommend to buy it only through Company's Web World and not from any franchised Web World Express.
Edited by Honest
this is bound to happen. :NOTriste:
when i went to buy my handset wwexpress :Equivocado: gave me an estimation of 6700/- :P while i got it for 6200/- :Chulo:
but what is its advantage over the data card which is again available at the same price :D and ffers about the same benegits :grin:
Data cards can only be connected to Laptops
this can be connected to Desktops also via Usb
Very much overpriced The same card can be FOund in $60 in USA
1. Is there any RUIM ??? in it
2. What is 1000 Chr SMS??
3. Does it mean Concanated SMS
4. No EVDO Support for Future Expansion
Rather go for Huewei CDMA / EVDO Card which also Support RUIM and it must available in $ 120 to 150 Range
data cards are available at abt the same cost.
;) some time back tata had introduced some dhamaka offer and was offering the same card at abt the same price of relaince data card available today.
be it from any manufacturer. :Riendo:
btw have heard that airtel giving the same card/ datacard at 7k but the unlimited use is given for 999/p.m. only. :)
which is 1500/- p.m. for reliance
ank unlimited 1500 plan (platinum) and 650 plan has been discontinued in usb .
these are available only in pcmcia card now
^^^^For new or existing customers plz specify
For new customers .
existing customers i think would continue enjoying .
For new customers .
Two months back i got reliance data card for 5000 and a adapter for tat to insert in my desk top tat around 1200......
i dont know about this usb data card...
oh man wasted rs 1700 :P
Edited by supernova
is the data transfer speed comparable to data card :)
Hi ..
I have a airtel data card whic i would like to sell , its a new card just one and 10 days old. I don't have PCMCIA slot in my HP laptop which i bought from US, anyone one interested just me mail on raghubhat82@gmail.com
Hi ..
Please Post the Buy / Sell related queries in Buy / Sell department that will be more relavant
This seems very silly of reliance that USB is not available for freedom and platinum plans,, Today i called up Cust care, the silly girl on phone said USB is available on all plans including platinum, CAN ANYONE PLZ CONFIRM
may be there are regional variations. here cc guy was telling that because internet cafe people using usb on lan and thats put pressure so they have discontinued on usb
:NOTriste: some time back tata had introduced some dhamaka offer and was offering the same card at abt the same price of relaince data card available today.
be it from any manufacturer. :Chulo:
btw have heard that airtel giving the same card/ datacard at 7k but the unlimited use is given for 999/p.m. only. :confuse:
Airtel Data cards now available for 5000/ and unlimited plan for 999/ month.. reliance unlimited plan is very overpriced at 1500/
:GirandoOjos:
Just bought a HP DV6226US Laptop from the US. The OS is Windows Vista Home Premium.
My Reliance USD Data Card EC325 did not work at the first go. I had to play around a bit to get this to work.
1. Install the Reliance Netconnect software from the CD.
2. If the Huawei Connect software does not recognize the Data card, go to Device Manager.
Vista will assign multiple ‘data interface’ devices under the ‘Other devices’ category for the data card.
Right click the device, select ‘Update Driver Software…” and browse to Reliance CD. Make sure ‘Include Subfolders’ is checked.
Repeat for all other ‘data interface’ devices. Vista should indicate the successful installation of the following devices:
- HUAWEI Mobile Connect – 3G Modem
- HUAWEI Mobile Connect – 3G Application Interface
3. Shutdown and re-start the laptop. Restart the Huawei connect software and Connect. If you get a "Connection Failed: Please check the wireless device or the Settings of the Network connection" , you will need to setup a DUN manually:
- Click ‘Start’ and ‘Connect To’
- Click on ‘Set up a connection or network’
- Select ‘Set up a dial-up connection’ and click Next
- Select the data card modem.You will be prompted to choose between Huawei Modem and Huawei Data/Fax -- Select Huawei Modem
- Enter #777 into the dial-up phone number field
- Enter username and password and enter ‘Reliance’ or something similar as the connection name
- Click Connect
If all goes well, you will be connected to the Reliance Wireless Network. Going forward, you will need to use this Network connection whenever you need to connect to their network -- The Huawei Connect program may not work.
My guess is that the second Huawei Data/Fax device is causing the Huawei Connect program to fail. If somehow this second Fax device can be removed or uninstalled, things may work normally. Will check into this and post my findings.
Good luck and drop me an email at apurva.pradhan@gmail.com if you have any queries.
Apurva
PS: By the way, if you call Reliance Support at *333, they will promptly tell you that the Data Card does not support Vista and that they have mentioned it clearly
on the Data Card packaging box (which is true). Not much helpful isn't it :dontknow:
