reliancenokia2007
Nokia 6275 Charging Continously
just bought a nokia 6275. kept it charging for 3 hours after a complete discharge. indicator does not show charge cycle completion. just keeps on charging. does this indicate a defect ??
wondering if anyone had a similar problem before??
battery is authentic according to www.nokiaoriginals.com/check instructions and online verification.
Edited by reliancenokia2007
That is a bug in the software for ur phone.....
Dont know that Nokis is up with the latest release.... and if they are then u can get it from the Nokia Priority at no extra cost...
Just get the firmware upgraded that is all wat i mean.....
I think u playing around with handset while its on charging,
New batteries takes lil extra time thn usually it takes to complete charge.
i've visited nokia care today. engineer informs me that the particular handset battery BL-6C requires 6 hours of initial charge. IMO its high but i'll give it a try.
if the problem lies with mobile firmware it is sent to Delhi for further analysis. 40 days of blackout.
Replacement is possible within 48 hours if the handset is bought from Nokia Priority Dealer (NPD).
too bad the handset wasn't bought from NPD :NOTriste:
I think Nokia come with via two different channel
one is HCL-Insys and Another is nokia itself. So there might be differencial service. But I think these Two channel only distribute the products and Services is DOne Directly Nokia
There Should be Priorioty or Off-Priority THings
and If it gonna take this much time try another Borrowed Battery BL6 and check out that the Problem is getting sorted out or not
at last 6 hours of charging halted handset charging indicator. nokia care engineer was right.
i'm relieved :NOTriste:
thanx to all who contributed their valuable suggestions.
Dear mods,
i think the issue is resolved so we can close the topic here...
thanks.
eveni m facing the same problem...
i bought it some one month ago...
even after charging for 6 hrs. still the problem exists...
WHAT TO DO GUYS>>>
