DEV 0 Report post Posted May 20, 2004 Hi, I got LG RD2130 moon light few days back with Post paid connection. Few days later I got USB Data cable which was of RD2030, RWW personal told that it will work ok, no problem,, now I am trying to install, dialar, modem, driver etc on my laptop, but the installation screen doesnt move to Next even after driver gets installed properly? Let me know if anyone has experienced same problem.... I appreciate your help. Thanks, Dev. Share this post Link to post Share on other sites
Ganesh 0 Report post Posted May 20, 2004 same thing came with me. uninstall the driver. reinstall it. and wait exactly for the given menu. it may even take 10 mins to continue to next step be patient. it worked for me Share this post Link to post Share on other sites
DEV 0 Report post Posted May 21, 2004 Hi, R u sure YOU had USB 2030 Datacable and not Serial/COM cable? thanks, Divakar. Share this post Link to post Share on other sites
