deshmukh_bhushan
Problem In Accessing The Browser On 7135 Pda
I am following the below process, BUT the msg "CANCELLING" is comming and not able to establish the connection.... pl. help
step 1 ...go to "preference PDA"
step 2 ...in that go to "network" option from right top
step 3 ...type ur username as ur phone no. n password also ur phone no.
eg: - user name : 9327093270
password : 9327093270
press "connect" ..
aftr d proccess it will say established messege..
Thank you..
Hi ,
Now i am able to connect, the connection is happening successfully with "Established" msg. But in EIS browser when i am putting address like http://www.yahoo.com/ & http://www.rediffmail.com/ , The ERROR msg is comming that ""The page you are trying to display cannot be found. Pl. check the address and try again.
When I am using the Web Pro browser the ERROR msg is ""DNS error. Please check coverage, check that the HostAddress in Preference is correct and try again [4688]..
Please help me and suggest how can I surf the internet / web on my PDA 7135...
Bhushan
Still I am not able to surf...........In the network menu , below setting im using
1)
Service : Reliance
User Name : 9370408152 (my cell number).
Password : 9370408152
Connection : Wireless modem
Phone : #777
2) In details menu near connect
""Connection type : PPP"" (when PPP it shows cancelling & connection fail.....whn "SLIP" or "CSLIP" it establish but surfying dosen't happen- in browser error comming " can not find the page.. pl check the address and try again)
Idle timeout : Never
Query DNS: ticked
Ip address : Automatic
I realy do not know why it is happening.........where is the problem...........Pl. help me in solving this problem...
my cell no.- 9370408152..
