abhilove1984
Help Me To View Movie
help me
i want to know that how can i use the files with .001,.002 extention.
EDIT by Vishal Gupta: < Links Removed >
i download all parts of movie but how can i see this tell me.
how can i convert these parts in video format
(1) Open any of those files manually with WinRAR (it doesnt matter which one) by dragging and dropping them onto WinRAR.
(2) Select all the files and extract them somewhere, you may be extracting another set of 001, 002, 003, etc files or you may be extracting a BIN/CUE file. If you are extracting the former, then just repeat this process until you get a BIN/CUE file or soemthing you are expecting.
(3) When you've got the BIN/CUE, burn it using Nero or something like that and you're done
<< please post in the right forums - moving topic to General Technical Discussion >>
Its very likely its a split archive created using something like HJSplit. If it is, then I doubt if Winrar will work! It might make more sense to try with HJSplit 1st as it needs no installing, is free, and is very small & easy to use...
Edited by raccoon
Guru.2007.Pre-DVDRip_1CD_BY_Deejam.001
Guru.2007.Pre-DVDRip_1CD_BY_Deejam.002
Guru.2007.Pre-DVDRip_1CD_BY_Deejam.003
Guru.2007.Pre-DVDRip_1CD_BY_Deejam.004
Guru.2007.Pre-DVDRip_1CD_BY_Deejam.005
i have five parts of movie in above format, i have also combine these with hjsplit but not working winrar also not working.
You gotta specify what exactly is not working dude...! I mean any error msgs or is it making the output file or are you having problems playing the video file ...or what?
Edited by raccoon
