sanjaysh 0 Report post Posted February 8, 2007 I have a Nokia 3105, with a CA-42 Cable . When i connect the cable tthru the PC suite, it can access the data on my phone, but am not being abel to connect it to the net. When i installed the rconnect_nokia_us software to set up the phone, it installed the DKU-5 cable software to my PC. Where do i get the netconnect for a CA42 cable. OS on my PC is windows XP professional . Nokia PC siute is version 6.82 And in the device manager, no modem apart form the one on my laptop is visible. Where do I get the Rconnect dailer software that can be installed for a 3105 connected thru a CA42 cable . Is there a place from where i can download the same . A prompt reply wud be appreciated !! Share this post Link to post Share on other sites
HetalDP 947 Report post Posted February 9, 2007 Attached isthe Modem Driver for Old DKU-5 or CA-42 Phones Just Install the Modem on COM Port of CA-42 Cable then Create the Dialer Start - Setting - Network Connection - Create New Connectoin Follow the Following Step Connect to INternet Setup Connection Manually Connect using Dialup Modem ISP Name = Reliance NetConnect Phone Number = #777 User name and All Password = Your Mobile Number Tick Add Short Cut to Desktop Nokia_CDMA_Modem_Driver.zip Share this post Link to post Share on other sites
sanjaysh 0 Report post Posted February 9, 2007 (edited) Attached isthe Modem Driver for Old DKU-5 or CA-42 PhonesJust Install the Modem on COM Port of CA-42 Cable then Create the Dialer Start - Setting - Network Connection - Create New Connectoin Follow the Following Step Connect to INternet Setup Connection Manually Connect using Dialup Modem ISP Name = Reliance NetConnect Phone Number = #777 User name and All Password = Your Mobile Number Tick Add Short Cut to Desktop Thanks Hetal, But the zip just contained the Modem Setup Information file and not the setup files. If you could please send me the Setup Files it will be great !! Thnaks a lot. Edited February 9, 2007 by sanjaysh Share this post Link to post Share on other sites
sanjaysh 0 Report post Posted February 9, 2007 Just adding another post so that i can get email notification of ur reply . Actually what i need is a Moden driver supporting CA-42 cable !! You got my prob like BULL's EYE !! Will look forward to hearing form you ! Share this post Link to post Share on other sites
HetalDP 947 Report post Posted February 9, 2007 Just go to COntrol Panel, Phone and Modem and Add Modem on the Port of CA43 Cable when ever it will ask for Driver disk just give the location of inf file i have attached this is a Generic Modem INF so the Driver used it self is from XP only. ReAttaching the Modem INF FIle nmpCDMA1xRTT.zip Share this post Link to post Share on other sites
