gr8usr
Big Problem With 6265 Help
I wanted to change the banner name on my 6265 so i changed it thro the *3001#12345# alpha tag,. then i just looked into the values of the other entries there..
When i came out of the menu it now just says searching for network ...i cant make or recieve calls..
Should i try restarting it....what if i am unable to access the menu once i restart???
can anyone give me settings to make it work???
please help..
Just Restart the Phone and Then Check it wil be OK after it.
