vbraju
Differences Between 6265 And 6275
Hi
Can someone please give a list of differences between 6265 and 6275. I am just curious why 6265 is 4-5k more expensive than 6275 when all the features are the same. Is it just because of the form factor (slide vs. candy bar)
Best Regards
V B Raju
It just b coz of Form Factor and 4 mm Shorter Screen in 6275.
2 Differences I figured out. 1 is very Minor one.
The applications are slightly different then 6265. Like Calculator in 6275 is way better then 6265.
The big difference is that 6265's memory card has external slot and is not behind the battery. Where as on 6275 the Mirco Sd slot is behind the battery, so everytime you need to remove the card you have to turn the phone off.
OT, btw i remember u said u were going to post nokia calculator in 6275. what happened? can u pls do it?
I am trying to get that Calc, but not sucessful yet. I am not aware of any software which can extract Inbuilt applications of the phone. I assume when we go to upgarde the software for 6265, we should get the new Calc.
i never heard something like software upgrade from Nokia in CDMA
