ksudeep 0 Report post Posted February 27, 2007 Hi Gurus, I am facing some problem in installing Bluetooth on my new PC. Widcomm installer extractes upto Data1.cab and hangs. The same CD works smoothly on other PC but not on mine. I even tried to copy CD contents onto the harddisk and then ran. Its one and the same. Pl help. regards. Share this post Link to post Share on other sites
HetalDP 947 Report post Posted February 27, 2007 The RapidShare link for WidComm Bluetooth 5.0.8 is as below Install it it much smooth then any other widcomm version http://rapidshare.com/files/18512739/Widco....1.801.zip.html Share this post Link to post Share on other sites
ksudeep 0 Report post Posted February 28, 2007 Thanx-a-Ton Hetal, I've downloaded the installer. That particular PC is currently not accessible to me. I'll try to install it in the evening and reply you back. Thanx once again. Share this post Link to post Share on other sites
ksudeep 0 Report post Posted March 1, 2007 Yup....... Hetal, Its working. Thanx a lot. Share this post Link to post Share on other sites
rakesh5295 0 Report post Posted March 3, 2007 I have a motorla bluetooth handfree will it work on nokia or on computer? Share this post Link to post Share on other sites
