Naveed 0 Report post Posted May 24, 2004 I have connect my Lg2030 using uniCDMA software and by mistake click on write esn without changing any value. now my phone is not workin, when i do a call i hear a massage " Please call custamer service to resume" when i do call from other phone to RIM It says "Out of coverage area" but i got full network. please help me. Share this post Link to post Share on other sites
Ashokjp 15 Report post Posted May 24, 2004 Yeh your phone wont work without ESN. Btw do you know your ESN ? If so maybe it can be sorted out.. Else you have to take it to service centre Share this post Link to post Share on other sites
Ganesh 0 Report post Posted May 24, 2004 another fone SCREWED Share this post Link to post Share on other sites
Ashokjp 15 Report post Posted May 24, 2004 another fone SCREWEDÂ Hehe its k.. Dont get him too nervous Share this post Link to post Share on other sites
krimson.kryptonite 0 Report post Posted May 24, 2004 Hey Naveed buddy, No harm is done. dont panic. If you have noted down old ESN, just try writing that. It might take 2/3 attempts to write the ESN. So dont worry if you get an error or still see a 0 ESN. Alternatively, you can go to service center with some creative excuse... and they'll reprogram it for you. Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted May 25, 2004 Hey Naveed try to change Line#1 to Line#2 and vice-versa Share this post Link to post Share on other sites
Ashokjp 15 Report post Posted May 25, 2004 Hey Naveedtry to change Line#1 to Line#2 and vice-versa I dont think changing Lines would work when there is no ESN in the phone... You dont have to worry.. Just give it to the service centre.. They will get it done in a day... Share this post Link to post Share on other sites
iiii_pretender_iiii 0 Report post Posted May 25, 2004 Changing lines doesnt work, I had same problem, My esn got changed to 0 Service center guys only took 2 mins to fix that. No questions asked. Dont mess with the phone naveed, or you might change something else too (by mistake) and do more damage. Take it to the service center. Share this post Link to post Share on other sites
Ashokjp 15 Report post Posted May 25, 2004 hey while writing esn sometimes at first it writes the ESN as 0 In such cases just try writing once more, it will work properly Share this post Link to post Share on other sites
tiger 0 Report post Posted May 26, 2004 Don't worry and panic. Simply go to the service centre as if nothing happened and they will fix it. I know CDMA very well and for some reason (I don't know why - so don'y ask) in some sets the ESN suddenly becomes 0. Could be due to some internal technical reason like "shocks" or 'dropping the set". It is a regular problem faced by the Reliance service centres - just like the "service required" in the good old days. Bye Share this post Link to post Share on other sites
Tushar 0 Report post Posted May 28, 2004 BOTTOMLINE : Dont Try Messin It Up Anymore. Go To The Nearest LG Service Centre. Share this post Link to post Share on other sites
Surej 0 Report post Posted May 29, 2004 It's good for the forum to avoid topics like Cloning.... WBR Surej Share this post Link to post Share on other sites
