HetalDP
Software For Ppc2005
Starting the Thread to Post Exclusive Reply on Software which you have tested and runnind on PPC.
Please Be sure You have Installed it on your PPC and it is Running Perfectly.
Be aware PPC software may be infected by Virus so While uploading and Downloading Scan it with Anti Virus in PPC as well in PC
Edited by hpnasik
PPC as in ? what windows version .... 2003, win5, crossbow, win6 ??
You looking for anything in particular ?
i guess u mean Windows mobile 5 & above ?
Well hpnasik if u give me the firmware u currently using ( Rom version & Radio version along with date ) i could upload the new crossbow or windows mobile 6 version for u. Where softwares are concerned ... just name it and u will get it :) .
Ciao.
My ROM Version is 2.11.20 WWE
Rom Date: 04/04/06
Radio Verison: 1.19.00
Protocol Version : SNAZ-40306
I have just flashed my device to AKU 3.5 and my Os is
OS 5.1.195 (Build 15698.3.5.0)
1996 - 2006 Microsoft Corporation
Please let me know more details of the new crossbow or windows mobile 6
Rom Date: 04/04/06
hi..i have got a utstarcom with reliance, but want to move over to tata indicom..will it be possible ? pls help as quickly as possible..
hpnasik can help you as he is using verizon enabled handset with reliance
Google Earth or Google Maps
Now on PPC Just Installed it and It Extremmly Fast than Java Based Version
GoogleMaps.zip
wm5Storage
Now Plug Windows PPC with Computer as USB Mass Storage Device
So without Active Sync we can Copy the File to System
wm5_Storage.zip
Did you know that your SmartPhone is unable to accept a vCard if it is sent from a cellular phone?!
Share your contacts quickly and whenever you need. Sunnysoft vCard will add value to your contact and enable flexibily to react to new chalenges.
Basic functions:
send vCards via GSM to any cellular phone
receive vCards via GSM from any cellular phone
automaticaly convert phone numbers from incomming SMS to contact name
Extended functions:
national character support
save last recipients number used
save multiple vCards
save vCard to contacts
context menu for vCard seding
support for Nokia phones
send vCard directly from contact list
filter recipient numbers
quick recipient search
send vCards as SMS (to phones not supporting vCard)
Supported operating systems:
Windows Mobile 2003 Phone Edition
Windows Mobile 2003 Second edition - Phone Edition
Windows Mobile 5 Phone Edition
Supported display modes:
SunnySoft_vCard_v1.1.zip
Edited by hpnasik
vSnap - Free Screen Capture Utility
Just map this Software with Any Key
Just go to Start - Settings - Personal - Buttons -
Map Button 4 (Press & Hold) with vSnap Program
Whenever you want to Capture the Screen Just
vSnap_0.2.zip
Edited by hpnasik
AutoSMS Reply
When u want to Reply any Caller automatically with some Predefined SMS when U can not Received any Call
This is Good Utility
Just Load this software in Main Storage
Auto_SMS_Reply_v1.5.zip
magiCall
Nice Call and SMS Blocker.
If somebody is bothering by calling or Texting
Just Block em up
magiCall.zip
SPB Mobile Shell v1.0 SPB Mobile Shell v1.0
Requirements: WM5
Overview: Spb Mobile Shell introduces the next generation user interface while keeping all advantages of a Windows Mobile device.
Features
The most important information at one screen
Phone style menu
Weather forecasts
Photo speed dial
World time
Launcher
Big dynamic tabs on Today
Color based themes
Smart contact search
Auto-hide mode for Today plug-ins
hello everybody Can not upload file Larger than 500 kb here
and 90% of Application of PPC is large than that.
I am Loading a Bulk 7z format file into RapidShare
You will require 7Zip Freeware Utility for Extracting it into Disk
http://www.7-zip.org
The link to the file as Follows
http://rapidshare.com/files/22847300/Installable.7z.html
The Following Software have been Included
  1. Adobe Reader 2.0
  2. Airscanner Mobile Antivirus
  3. Airscanner Mobile Sniffer
  4. Anton Tomov Pocket Mechanic Professional v2.23.163
  5. Arcsoft MMS
  6. Atom Dial Pad
  7. Auto SMS Reply v1.5
  8. BatNAV11
  9. BT Remote Setup 0.5.0
  10. ByteWired RegEditor
  11. ClearTemp
  12. CrazySoft Astrology Horoscope Pro 1.1
  13. Crossbow BootScreen
  14. Crossbow Theme
  15. Efficasoft Mobile Express 1.1
  16. EnableRAPI
  17. FastCleanup
  18. Flash7
  19. Flexi Mail 2007
  20. GoogleMaps
  21. HPMobile Print
  22. iLauncher3.0.0.4.Only.WM5
  23. Inesoft Address Book 1.66
  24. Intent Midlet Manager
  25. Kaisoft.IR.BT.Manager.NET.v1.3
  26. LiveSearch
  27. magic Shote
  28. magiCall
  29. Megasoft PocketCalc
  30. MS.Net 2 CF
  31. MyIPConfig
  32. NeroMobile
  33. NetFront
  34. nPOP
  35. Opera86
  36. Pocket Birthday 1.2
  37. Pocket Cleaner
  38. Pocket Notepad v4.0
  39. PocketMax AlarmToday 2.43
  40. PocketRAR360
  41. PocketRun v1.01
  42. PPC Command Shell
  43. PPC6700 Drivers
  44. PPx
  45. Resco Utility Package v5.47
  46. RescoExplorer5.42
  47. Ringo Mobile 1.29
  48. ROM
  49. Rudeo Control for Windows Media Center 1.7
  50. Safe Mode
  51. SBSH Pocket Breeze 5.101
  52. SKTools 3.1.4
  53. smenu.arm.cab
  54. SMS COOL1.12
  55. SMS Scheduler 1.0.3
  56. spb
  57. Sprite Backup 510
  58. StorageTools 2.0
  59. StripPoker
  60. SunnySoft Backup Manager 3.7
  61. SunnySoft vCard v1.1 (Dont Install / SMS Stops Receiving & Sending )
  62. Talking Alarm 0.5
  63. TCPMP
  64. Total Commander
  65. TrueFax 2004 3.01
  66. Tweaks2k2
  67. UI Tweaker v0.3 PPC
  68. Ultimate Theft Alert v3 - GSM
  69. VeriChat v1.42b
  70. Vito Screen Capture
  71. VITO VoiceDialer 3.6
  72. Vito.Remote.v351.PPC.2003.SE.Patched
  73. vSnap 0.2
  74. WinAMPaq
  75. WinMobileApps Call SMS Blocker 1.2.0.86
  76. Wisbar Advance 2.8.0.3
  77. wm5-Storage
  78. XCPU Scalar 2007v3-01
Edited by hpnasik
Getting started
Skype for Windows Mobile is now even easier to use. Here are a few tips to help you get the most out of Skype on your device.
Use a headset
By default, Skype calls are made over the loudspeaker, so you’ll want to do this to avoid upsetting everyone on the train. Most devices come with a hands-free kit.
Getting connected over WiFi
Skype can’t connect to the internet for you. This is something you’ll need to do yourself before you sign in. Please refer to your device’s manual to find out how to do this.
Maximising battery life
WiFi can be a serious drain on a device’s battery. You can save your battery by signing out of Skype when you’re not using it. Turning off WiFi when you plan to be offline for a while will also improve battery performance.
Your contacts
On most Windows Mobile devices, Skype works best when you have less than 100 contacts. It may be better to set up a new mobile account and have all your popular Skype contacts on this profile.
Using Skype on 3G while roaming
Before you go abroad, check the costs uof using your 3G connection while you’re roaming, as this is often very expensive. Many hotels offer WiFi for free, so you’ll be able to use Skype on your device and enjoy making free calls without running up huge mobile phone bills.
Now Use Skype Instant Messaging and Voice & Video Confereing with Voice Calling on your Reliance PPC 6700
Download Skype 2.1 from
http://www.skype.com/go/getskype-pocketpc-cab
Hi Hetal Thankx for the above softwares with description
:Sorprendido: Keep up the good work
Dear Friends Hetal and mahendra
thanks for ur lovely softwares and upgrades
im facing some problems
i have installed inesoft 1.67(latest)
callerid doesnt work correctly, when i manually start it, it works perfectlybut when i softreset the phone it doesnt start automatically
im facing the same problem with photocontacts pro
also hetal
when u gave the backup / restore file of all ur softwares the dialpad had a very loud keypad tone
how have u done that?
regards
atul jain
good job hetal ... indeed you're just too goood .... !
Keep it up & let more of ur good work coming .... !
Cheers!
