paraggogari 0 Report post Posted March 23, 2007 hi guys, i bought NOkia 6275 reliance before two weeks & i face few problems with my cell. 1) It gets HANG, shockingly few times it got hang, & my ringtone was kepp on playing. i was not being able to do anything , it was not getting switched off also. than i had to remove battery. some time it gives UIM error. 2) Navigation key & phone pick up / cancel keys are of not good material it bends downwarsd & not clickable properly. do any one face same problems or can any one tell me why my mobile gets hanged??????? Share this post Link to post Share on other sites
supernova 47 Report post Posted March 23, 2007 i also face problemof handset getting hang sometimes . after some times it restarts Share this post Link to post Share on other sites
HetalDP 947 Report post Posted March 24, 2007 Same with me while using it in Bluetooth Dial up Mode the Phone show White Blank Screen and Then Show the Previou screen and then Reconnect the CDMA Tower !!! Please everybody is there any Firmware Update available as this is RUIM Based I will Remove RUIM and Get it Flashed with Nokia care. But Before we have to confirm that new Firmware is available. Share this post Link to post Share on other sites
paraggogari 0 Report post Posted March 24, 2007 & its HEADPHONE volume is too slow....even after increasing it to maximum u can't hear voice in traffic etc.... do any one face this problem & pls tell me are KEYS of the phone fine as i find it gets bent. its not at all soft. Share this post Link to post Share on other sites
Saurav 22 Report post Posted March 25, 2007 Yes headphone volume is really very slow. Is there any bluetooth Handsfree with inbuilt amplifier. Share this post Link to post Share on other sites
reliancenokia2007 2 Report post Posted March 25, 2007 (edited) i agree that the navigation key is clumsy... phone hangs only when i try to do 2 many things in succession. this happens more with a custom theme applied which is heavy on the graphics side... using default nokia themes speeds up navigation... i've never experienced restarts with this handset... restarts were a regular feature of the LG RD7130... i don't know if it ever was resolved... i sold off my handset ultimately for peanuts... Edited March 25, 2007 by reliancenokia2007 Share this post Link to post Share on other sites
shaileshtutors 0 Report post Posted March 25, 2007 No my phone are not hangs up at all If we load more and more extra themes than only it hangs thats true yes headphone slow volume is there initially i thought its defective handset but i confirmed with nokia for this Share this post Link to post Share on other sites
@v@nit 3 Report post Posted March 26, 2007 My Phone never hanged and is working fine with custom theme and lots of application & games. Share this post Link to post Share on other sites
satyender_tyagi 0 Report post Posted March 29, 2007 & its HEADPHONE volume is too slow....even after increasing it to maximum u can't hear voice in traffic etc....do any one face this problem & pls tell me are KEYS of the phone fine as i find it gets bent. its not at all soft. Keep ringing volume to max, it will work. Share this post Link to post Share on other sites
thomas_77 0 Report post Posted May 4, 2007 (edited) I am also facing same issue of Phone gets white screen & it reboots while using net thru modem , i find its only if you are using the connectivity by blue tooth once suddenly my phones software got hanged while not using net also & finally i had to remove the battery cos switching off also was no solution i just dont understand why its happening , i when to nokia dealer he is just giving some carp answers , its really strange ,,, even the PC suite nokia almost all versions i tried , small files are getting transfered but the moment i transfer a file more than 1 mb blue tooth connection gets lost ........ but if i use the blue tooths software to transfer the file there is no problem ,,, dont know why such a pruduct is not tested before providing it to customers , dose any one have any solution , do post it please I Edited May 4, 2007 by thomas_77 Share this post Link to post Share on other sites
kk999 25 Report post Posted May 4, 2007 1)I am also facing problem of handset getting hang sometimes and after some times it restarts. problem comes I use blue tooth for file transfer and send 5/6 (2,3,5....mb)files after 2/3 file hang my nokia 6275. but I use DKU-2 no problem. 2)I also facing new problem in use of FM.I set FM station after screen light of some sound come in HEADPHONE. Share this post Link to post Share on other sites
Greens 21 Report post Posted May 5, 2007 I believe the hanging and rebooting is almost common in all range of NOKIA CDMA phones. The service centres are totally usesless. Share this post Link to post Share on other sites
thomas_77 0 Report post Posted May 6, 2007 (edited) I found one more thing if you are using Internet via bluetooth & phone is not charging at the same time then i found no hang ups ,,,, but when i used while charging battery then 6275 hanged at least 2 times in around 40 mins ,,,,, guys you can also have your feed back on this Edited May 6, 2007 by thomas_77 Share this post Link to post Share on other sites
vishal 0 Report post Posted September 7, 2007 Does 6275 supports MP3 ringtones ? Share this post Link to post Share on other sites
DEVJADAV 0 Report post Posted September 7, 2007 Dear Friends, Reg. Nokia 6275 I just want to know how to surf other sites like RIMWEB.IN and also how to access my own emails. Pl. guide me. Thanks, Deven Share this post Link to post Share on other sites
hilsaboy 0 Report post Posted September 16, 2007 Hi, My 6275 headphone also has poor sound in traffic. I can't listen anything in traffic. Also I Wanted to remove Rworld from the right side button(Left side is GOTO). pleease tell me how to remove. Share this post Link to post Share on other sites
Saurav 22 Report post Posted September 17, 2007 even I am facing similar problem i hate to use its headphone when in bus. Share this post Link to post Share on other sites
