HetalDP
Li-poly Vs Li-ion Batteries
Lithium ion polymer batteries, or more commonly lithium polymer batteries (Abbreviated Li-Poly or LiPo) are rechargeable batteries which have technologically evolved from lithium ion batteries. Ultimately, the lithium salt electrolyte is not held in an organic solvent like in the proven lithium ion design, but in a solid polymer composite such as polyacrylonitrile. There are many advantages of this design over the classic lithium ion design, including the fact that the solid polymer electrolyte is not flammable (unlike the organic solvent that the Li-Ion cell uses). Lithium ion polymer batteries started appearing in consumer electronics around 1996.
Overview
Cells sold today as polymer batteries have a different design from the older lithium ion cells. Unlike lithium ion cylindrical, or prismatic cells, which have a rigid metal case, polymer cells have a flexible, foil-type (polymer laminate) case, but they still contain organic solvent. The main difference between commercial polymer and lithium ion cells is that in the latter cells, the rigid case presses the electrodes and the separator onto each other, whereas in polymer cells this external pressure is not required because the electrode sheets and the separator sheets are laminated onto each other. Since no metal battery cell casing is needed, the battery can be lighter and it can be specifically shaped to fit the device it will power. Because of the denser packaging without intercell spacing between cylindrical cells and the lack of metal casing, the energy density of Li-Poly batteries is over 20% higher than that of a classical Li-Ion battery and approximately three times better than NiCd and NiMH batteries.
The voltage of a Li-Poly cell varies from about 2.7 V (discharged) to about 4.23 V (fully charged), and Li-Poly cells have to be protected from overcharge by limiting the applied voltage to no more than 4.235 V per cell used in a series combination. Overcharging a Li-Poly battery will likely result in explosion and/or fire. During discharge on load, the load has to be removed as soon as the voltage drops below approximately 3.0 V per cell (used in a series combination), or else the battery will subsequently no longer accept a charge.
Early in its development, lithium polymer technology had problems with internal resistance. Other challenges include longer charge times and slower maximum discharge rates compared to more mature technologies. Li-Po batteries typically require more than an hour for a full charge. Recent design improvements have increased maximum discharge currents from two times to 15 or even 30 times the cell capacity (discharge rate in amps, cell capacity in amp-hours). In March 2005 Toshiba announced a new design offering a much faster (about 1-3 minutes) rate of charge. These cells have yet to reach the market but should have a dramatic effect on the power tool and electric vehicle industries, and a major effect on consumer electronics; especially electrically powered model aircraft.
When compared to the lithium ion battery, Li-Poly had a greater life cycle degradation rate. However, in recent years, manufacturers have been declaring upwards of 500 charge-discharge cycles before the capacity drops to 80% (see Sanyo). Another variant of Li-Poly cells, the "thin film rechargeable lithium battery" has been shown to provide more than 10,000 cycles.
Applications
A compelling advantage of Li-Poly is that manufacturers can shape the battery almost however they please, which can be important to mobile phone manufacturers constantly working on smaller, thinner, and lighter phones. Another advantage of lithium polymer cells over nickel cadmium and nickel metal hydride cells is that the rate of self discharge is much lower.
Li-Poly batteries are also gaining favor in the world of radio-controlled aircraft, where the advantages of both lower weight and greatly increased run times can be sufficient justification for the price. However, lithium polymer-specific chargers are required to avoid fire and explosion. Explosions can also occur if the battery is short circuited as tremendous current would be available for a short time. Radio control enthusiasts take special precautions to ensure their battery leads are properly connected and insulated. Specially designed electronic motor speed controls are used to prevent excessive discharge and subsequent battery damage. This is achieved using a Low Voltage Cut-off (LVC) setting, that is adjusted to maintain cell voltage at (typically) 3v per cell.
Li-poly batteries are also gaining ground in PDAs and laptop computers, such as Apple's MacBook and small digital music devices such as iPods and other MP3 players, as well as portable gaming devices like the Sony PSP or Nintendo's Game Boy Advance SP, where small form factors and energy density outweigh cost considerations.
These batteries may also power the next generation of battery electric vehicles. The cost of an electric car of this type is prohibitive, but proponents argue that with increased production, the cost of Li-Poly batteries will go down.
Canadian company BionX had been supplying electric conversion kits for some time that used brushless motors and Nickel Metal Hydride batteries, but during 2006, they introduced batteries that used Lithium Ion technology. During 2007 Urban Mover introduced the first commercially available Li-Poly powered electric bikes, as opposed to just supplying conversion kits.
Edited by hpnasik
Good article.
Which are the current phone models having polymer battery,I remember seeing it in Nokia 6210 and 6310i.
Generally Polymer Battery are not shipped with Handset
But I have Imported Polymer Battery for PPC6700
The Same Old Size Battery for PPC6700
Old Li-ION Battery have 1350
New Polymer Battery with Same Same have 1500 mAh with Reduced Battery Weight.
It give Better than 30 % more Battery life
