neo_tech 0 Report post Posted May 27, 2004 Hi all, this is my new set from reliance. the set is latest...but the bad thing is that i can't find its covers anywhere in my city...searched the retailers, wholesalers, even the lg service centers! but no use . the set is getting dirty day by day. and i don't want to laminat my new handset. any idea how much time it takes for the new covers to be released? Share this post Link to post Share on other sites
rshivk 0 Report post Posted May 27, 2004 Laminate your phone. Not a bad option. Ask them to cut off a circular portion of laminated area at the back of the phone to enable heat dissipation. Share this post Link to post Share on other sites
neo_tech 0 Report post Posted May 27, 2004 hmmm....may be....but cover is far more better option than lamination, i mean u can take it off when ever u want, ur battery doesn't get locked in it, also it 'sticks' to ur mobile's battery...some side effect may take place in it :S. if my mobile would have been 8-9 months old then i might have gone for lamination but my handset is just 2 days old...i don't wanna take any risk, u know i hope the covers r released soon. Share this post Link to post Share on other sites
Chirag 5 Report post Posted May 27, 2004 The only issue with lamination is that it does not allow heat generated to be released. So i guess if u can take care of that then Lamination is definitely a better option. After all it hardly takes 10-15 bucks these days to get a lamination done. And its much better to get it done than let the handset get dirty! Share this post Link to post Share on other sites
Tushar 0 Report post Posted May 28, 2004 If you really wanna keep your phone clean laminate it for now and remove the plastic when U find a cover Share this post Link to post Share on other sites
jusmail 0 Report post Posted September 12, 2004 It is also difficult to get covers for 2130 here in Bangalore! So during my recent visit to Quilon, I bought myself 3 covers for 2130, just to be on the safe side. For those wanting covers in and around Quilon, 2130 included, visit the complex near the Reliance Web World at Geromenagar. Share this post Link to post Share on other sites
Ashokjp 15 Report post Posted September 12, 2004 Lamination is the best thing.. About the heat thing, i guess it doesnt make much sense if you put appropriate gaps in the lamination wherever u c holes in phone.. eg charger slot, mic etc.. Share this post Link to post Share on other sites
ssr 10 Report post Posted September 13, 2004 It is also difficult to get covers for 2130 here in Bangalore! So during my recent visit to Quilon, Hey jusmail, Have u tried in National Market or Bajaj complex next to National market? Share this post Link to post Share on other sites
manishag 17 Report post Posted September 13, 2004 plastic covers and laminations are harmful 4 the health of ur handset so plz try to avoid that better go for leather pouch Share this post Link to post Share on other sites
jusmail 0 Report post Posted September 14, 2004 It is also difficult to get covers for 2130 here in Bangalore! So during my recent visit to Quilon, Hey jusmail, Have u tried in National Market or Bajaj complex next to National market? No, I didn't check there. Do they sell them there? Share this post Link to post Share on other sites
Ganesh 0 Report post Posted September 14, 2004 Using lamination is a bad idea.the problem is when your mobile software gets hanged, the only way to make it normal is to remove the battery and replace it back.you will need to tear off the lamination to do this. am i right? Share this post Link to post Share on other sites
Code 0 Report post Posted September 14, 2004 May be .. but if U send a brew command to reboot it mostly agrees I always do that now using my Brew COM test app. Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted September 14, 2004 Hey code ur Brew COM test app was gr8. It worked on my FWP. Share this post Link to post Share on other sites
ssr 10 Report post Posted September 15, 2004 No, I didn't check there. Do they sell them there? jusmail If are free then go to Bajaj complex and there will be minimum 1 shop in each floor who will cell all these things I did not know about covers but i found data cables and also you can bargane They seems to be having covers, data cables chargers for all kinds of phones Share this post Link to post Share on other sites
rim-matrix 0 Report post Posted September 23, 2004 hi ppl, i saw new covers are avail, but they look the same as the original one. they don;t have fancy covers, one like nokia has, hope that''ll come soon. Share this post Link to post Share on other sites
