DEV 0 Report post Posted May 27, 2004 Hi fellas, I am facing serious issue with LG-RD2130. Here is the panic history. 1. Got RD2130 2. Got USB Cable of LG RD 2030 (Reliance Web world personal said it will work). 3. Tried installing on XP-Home edition. 3.1. No luck, . Next button was not coming even after I followed USB-Serial driver installations. 4. Now Trying on Linux PCQ2004. 4.1 downloaded Rconnect Linux installation script. 4.2. Tried to Install but they dont have installaer for USB cable for RD 2130. 5. All above resulted in great nightmare.. any help is more than welcome. Thanks, Dev. Share this post Link to post Share on other sites
StaticElectricity 8 Report post Posted May 27, 2004 hey have you read this USB Not recognised / USB-Serial Converter Share this post Link to post Share on other sites
rshivk 0 Report post Posted May 27, 2004 I didnot have any such problems. I could install RD2030 drivers and use RD2130. You may uninstall earlier drivers if any and then do fresh installation. But if you follow the instructions while loading RD2030 driver, you should not face any problems. Good luck. Share this post Link to post Share on other sites
DEV 0 Report post Posted May 28, 2004 hey have you read thisUSB Not recognised / USB-Serial Converter Hi, I went through it.. but mostly it focuses on hacking phone, which I am not intended to do for time-being. Yesterday I tried with xppp ... it was trying to initialize the modem but never got response(OK) from my RD2130.. i was connecting to /dev/ttyUSB0 and tried with /dev/usb/ttyUSB0 also... I dont now what could be wrong... also when I do modprobe uhci.. its giving error.. I think its using usb_uhci.o instead of uhci.. tried building kernel also, but no luck errors in building.. push me ahead with few more info... thanks, Divakar. Share this post Link to post Share on other sites
24x7netuser 0 Report post Posted June 11, 2004 Though the r-connect dialer s/w is ok - i found it best not 2 use it @ all - it installs all kind of unnecessary files on your pc that apart from taking up space (also creating entry in the program list) can get bothersome for techie users who prefer to do it the simpler way. CAUTION - only for experienced users - I do not take responsibility of any mess you make while you are following these instructions: here is what i do (assuming u hve a pc free of r-connect s/w - if u hve the s/w - u hve 2 uninstall it and also the modem(phone) drivers) 1. turn pc on 2. plug in yr phone (if u hve usb adapter - if there is serial connector - connect it first nd then turn on pc) 3. wait 4 pc to recognize new hardware (if it dosen't - go 2 control panel - add/remove h/w and search 4 new h/w) 4. when the wizard asks 4 drivers 4 new h/w tell it 2 look in the r-connect cd (in proper location) 5. it will install drivers and then say found new modem - repeat the process -tell it to look in the cd at the correct location 6. create a new dial-up connection with phone no. to call #777, usrnme nd pwd as your rim # with std code but without the 1st 0 eg if yr no. is 08031234561, enter usrnme nd pwd as 08031234561. use tone dialling. modem 2 use - select your rim phone modem - if it does not appear in the list of modems - repeat steps 4-5 till it does. 7. create shortcut on desktop 8. double click on it - connect nd y u ready 2 go cheers nd njoy Share this post Link to post Share on other sites
Ravish 0 Report post Posted December 14, 2004 The same thing happend with me today. Reliance dont have USB drivers for RD2130. I will try the serial cable with USB convertor tomorrow. Share this post Link to post Share on other sites
Ganesh 0 Report post Posted December 15, 2004 usb drivers for 2030 and 2130 are the same. Share this post Link to post Share on other sites
maniacr 0 Report post Posted February 12, 2005 Hi Guys .... I am facing the same problem....The installer would not enable next button.. PH:2130 XP/2000 USB. Do suggest something...I tried to follow the other replies but none directed me to the result. Used USB 2030 cable and software... -Mani Hi fellas,I am facing serious issue with LG-RD2130. Here is the panic history. 1. Got RD2130 2. Got USB Cable of LG RD 2030 (Reliance Web world personal said it will work). 3. Tried installing on XP-Home edition. 3.1. No luck, . Next button was not coming even after I followed USB-Serial driver installations. 4. Now Trying on Linux PCQ2004. 4.1 downloaded Rconnect Linux installation script. 4.2. Tried to Install but they dont have installaer for USB cable for RD 2130. 5. All above resulted in great nightmare.. any help is more than welcome. Thanks, Dev. 6915[/snapback] Share this post Link to post Share on other sites
