AGK 0 Report post Posted April 7, 2007 Hi guys,This is my first post.I really like this site and it is very informative.Can you guys tell me how to access gmail in my mobile.i am using LG 6130.please reply Share this post Link to post Share on other sites
Arun 795 Report post Posted April 7, 2007 The Web Mail application should be the only way for accessing Gmail on LG RD 6130. Share this post Link to post Share on other sites
Sadikk 301 Report post Posted April 7, 2007 Hi guys,This is my first post.I really like this site and it is very informative.Can you guys tell me how to access gmail in my mobile.i am using LG 6130.please reply Change ur handset to any nokia WAP enabled phone Share this post Link to post Share on other sites
HetalDP 947 Report post Posted April 8, 2007 Gmails Java Application will not run in any Reliance phone Because of Certificate Issue Any WAP Eabled Phone can go to gmail.com and check Email over there Share this post Link to post Share on other sites
petar 15 Report post Posted April 8, 2007 How abt PPC 6700 ? Does Gmail Java App work on it ? Share this post Link to post Share on other sites
HetalDP 947 Report post Posted April 10, 2007 Gmail JAVA Application work Perfectly on PPC6700 as it have inbuilt Certificate for SSL based communications I my self is using Intent Midlet Manager for Running Java Applications Share this post Link to post Share on other sites
bestbrain 0 Report post Posted April 29, 2007 will it work on Nokia 2865? is there any way to install cert. manager? Share this post Link to post Share on other sites
Kunal Hemrajani 1 Report post Posted April 30, 2007 will it work on Nokia 2865? is there any way to install cert. manager? Gmail app is workin perfectely on my nk6235.. and so u cud expect it to work on nk2865.. but u wont b able to download the gmail app on ur 2865 thru wap.. the only way is to install the jar file of gmail app(to get the jar file go to the thread nk6235 it is posted there).. then u cud access gmail.. Share this post Link to post Share on other sites
bestbrain 0 Report post Posted May 2, 2007 will it work on Nokia 2865? is there any way to install cert. manager? Gmail app is workin perfectely on my nk6235.. and so u cud expect it to work on nk2865.. but u wont b able to download the gmail app on ur 2865 thru wap.. the only way is to install the jar file of gmail app(to get the jar file go to the thread nk6235 it is posted there).. then u cud access gmail.. thank you for help. i am unable to find the application can you please help by uploading it again. BTW, i could download it from gmail.com/app but it gives certificate error. Share this post Link to post Share on other sites
mandu1 1 Report post Posted July 21, 2007 will it work on Nokia 2865? is there any way to install cert. manager? Gmail app is workin perfectely on my nk6235.. and so u cud expect it to work on nk2865.. but u wont b able to download the gmail app on ur 2865 thru wap.. the only way is to install the jar file of gmail app(to get the jar file go to the thread nk6235 it is posted there).. then u cud access gmail.. thank you for help. i am unable to find the application can you please help by uploading it again. BTW, i could download it from gmail.com/app but it gives certificate error. go to gmail.com/app Share this post Link to post Share on other sites
