afzal_6339
Nokia 6265 Theme Download Problem
I cant save the theme directly to mobile download from wap.mobile9.com. but there is the option to apply the theme. after exiting the browser, the default theme will appear....
Is there any remedy????????
Yes, the remedy is to download the theme to your PC and then transfer it to your mobile using data cable.
Direct download on the cell is not supported...
