nitojose 0 Report post Posted May 7, 2007 My classic 631 is just 3weeks old. With no reason the phone display nothing.. just a glowing screen! But i receive incoming calls. Is there anything i can myself to correct this? What the actual problem will be? Share this post Link to post Share on other sites
supernova 47 Report post Posted May 7, 2007 you wont be able to solve . these classic are cheap sets with low quality . visit your nearest service centre and insist them to replace Share this post Link to post Share on other sites
raccoon 53 Report post Posted May 7, 2007 Well, my brand new GSM Nokia very recently (just about 2 weeks old) went the same way - blank display ...only the backlight comes on. Ringer wont work either. They repaired it in warranty, but in 4 hours its back to square A. They wont replace it either. It is also made in China ...but its a Nokia ...seems Nokia is going the Classic way! Beware!! Share this post Link to post Share on other sites
nitojose 0 Report post Posted November 2, 2007 Though very late to reply to this... After 2weeks of my set problem(blank display), i took the handset to the nearest Classic Service centre and they replaced the LCD screen free of charge and that too within 10mnts. As all thought, i too considered Classic a cheap mobile. Yes it is. But it is cheap because it doesnot have RWorld and built-in modem! So worth to buy. Also most of the models' keypad acts like scratch proof and corrossion resistant! Share this post Link to post Share on other sites
Honest 836 Report post Posted November 2, 2007 ^^^ My dear friends many companies consider their handsets as DOA (Dead On Arrival) if the problem persists within 7 days of the purchase. After seven days they only will repair it under warranty and does not replace the handset at all. Regards. Share this post Link to post Share on other sites
Baumann 0 Report post Posted November 5, 2007 When such things happens, i tell my friend just to go to the dealer and they should fix it. Share this post Link to post Share on other sites
nafisaas 0 Report post Posted November 12, 2007 My classic 631 is just 3weeks old. With no reason the phone display nothing.. just a glowing screen! But i receive incoming calls. Is there anything i can myself to correct this? What the actual problem will be? You can do nothing I have bought classic 761 just 3 months back and now its display is blank and they are asking for Rs.550 to repair it.It has not fallen from anywhere and its no fault of mine.And its still under warranty period but you know all their exceptions comes only after we have purchased,they say that this is not covered under waranty.They have not mentioned this anywhere and I am surely going to forward this matter into the Consumer forum Share this post Link to post Share on other sites
nafisaas 0 Report post Posted November 12, 2007 You can do nothing I have bought classic 761 just 3 months back and now its display is blank and they are asking for Rs.550 to repair it.It has not fallen from anywhere and its no fault of mine.And its still under warranty period but you know all their exceptions comes only after we have purchased,they say that this is not covered under waranty.They have not mentioned this anywhere and I am surely going to forward this matter into the Consumer forum My classic 631 is just 3weeks old. With no reason the phone display nothing.. just a glowing screen! But i receive incoming calls. Is there anything i can myself to correct this? What the actual problem will be? You can do nothing I have bought classic 761 just 3 months back and now its display is blank and they are asking for Rs.550 to repair it.It has not fallen from anywhere and its no fault of mine.And its still under warranty period but you know all their exceptions comes only after we have purchased,they say that this is not covered under waranty.They have not mentioned this anywhere and I am surely going to forward this matter into the Consumer forum Share this post Link to post Share on other sites
Honest 836 Report post Posted November 14, 2007 ^^^ @Nafisa Shaikh Yes my dear friend, don't let them take you granted. You must forward this matter into the Cosumer forum. We all are with you my dear friend. Go ahead. Regards. Share this post Link to post Share on other sites
Mobile Man 0 Report post Posted December 27, 2007 ^^^@Nafisa Shaikh Yes my dear friend, don't let them take you granted. You must forward this matter into the Cosumer forum. We all are with you my dear friend. Go ahead. Regards. Rightly said. You should go to the consumer forum. Share this post Link to post Share on other sites
