drchetanshah
Usb Blue Tooth Dongle Problem
i just bought a usb blue tooth dongle for the nokia 6275
it is zippys
installed it from the cd
however, when i insert it in the usb port, the comp freezes and nothing works till it is disconected.
dont know what is wrong
it is zippys
I think its driver which freezing ur system.
Hetal patel will give u best solution.
I have not played that much with BT.
You can find him here my dear friend.
Hetal Patel's Profile
it is zippys
Plzz mention in details.. Which software u r using.. BlueSoeil,Microsoft,Widcomm or toshiba? which os u r using..
So it colud be easy to guide u.. :NOTriste:
