ramskr4u
Hardware Failure On My Fwp 350r Serial
I am using my FWP 350R for RConnect. I bought serial data cable from ebay.in. I have used this earlier successfully, after my transfer and SDA change. I got new number. When i try with new number it fails. I reinstall the software and check, it says as hardware failure.
I check with customer care, RConnect peoples ask me to check with LG service center. LG service center says that my FWP350R is working with their original LG Datacable.
Is any one help me to make my data cable work. Some guys told me to install the RConnect manually. I don't know how to install it manually.
Any help appreciated.
Rams.
