taarunya 0 Report post Posted June 7, 2007 Hi I bought reliance data card hastily then discovered that my laptop was not compatible.The webworld guys helped me transfer it to my bro's name.The process took some time.now he is not able to activate it.They say the time limit has been exceeded and it cant be used anymore.Rs 4200/- wasted. Contacted customer care.Reply is your account has been terminated. Help! Share this post Link to post Share on other sites
Sahyadri 0 Report post Posted June 7, 2007 HiI bought reliance data card hastily then discovered that my laptop was not compatible.The webworld guys helped me transfer it to my bro's name.The process took some time.now he is not able to activate it.They say the time limit has been exceeded and it cant be used anymore.Rs 4200/- wasted. Contacted customer care.Reply is your account has been terminated. Help! I think ur 4,200/- is not wasted. If you force the webworld ppl they will give u a new GSK (new number) and you can again activate it. If they don't provide the GSK for free ask them if you can buy a GSK (rs. 300/- approx) and this will work. Regards, Abhijeet Share this post Link to post Share on other sites
taarunya 0 Report post Posted June 21, 2007 Hi Thanks.I shall try that. Taarunya Share this post Link to post Share on other sites
supernova 47 Report post Posted June 21, 2007 hi !cool down your money not wasted . you can check status of ur acc by dialling *228 from your data card , if it says " enter 9 digit pin number" it means it is terminated ; and if it is not terminated then it wil tell you your number . and in case it is terminated ; then you can just buy a new postpaid connection (normally free otherwise rs 330 ) and activate it as per your choice plan . Share this post Link to post Share on other sites
mmjain 0 Report post Posted June 22, 2007 (edited) hi !cool down your money not wasted .you can check status of ur acc by dialling *228 from your data card , if it says " enter 9 digit pin number" it means it is terminated ; and if it is not terminated then it wil tell you your number . and in case it is terminated ; then you can just buy a new postpaid connection (normally free otherwise rs 330 ) and activate it as per your choice plan . Exactly And if when you dial *228 and you get the message "your phone could not be activated" it means that the Data Card of your is made "LOST" on the reliance network. You can get the data card made "FOUND" by talking to reliance Customer Care. You will have to give them the RSN No. of your Data Card and the Original Phone Number. This mostly happens when Customer Care uses RETAIL MDN to transfer the no.'s If You cannot get through Please let Me know the RSN No. and Phone No. with name and address details. I can HELP Edited June 22, 2007 by mmjain Share this post Link to post Share on other sites
