HetalDP
Hetal's Aku 3.5.4.b, Sprint Radio 1.27, With Registry Tweaks
  denttarek said:
  hetaldp said:
I have already Tried the Following Radio rom into my PPC
Verizon / Sprint / Reliance = Radio Ver 1.1
Telus = Radio ver 1.14
Alltel = Radio ver 1.15
now i have extracted the Latest Radio Version of Sprint from UTStarcomm December 2006 Unreleased Sprint Update
The Version is Sprint Radio 1.27
Just download the new rom and flash as per Guidence by the EXE
Hello there
i am Sprint user with ppc6700 i updated my rom using your update i am having a trouble connecting to my vision(internet)service and i don't quite understand what is the EPTS folder for and how to use the included files.thank you
Hey denttarek settings install with this ext rom is for reliance ( India based CDMA service provider) and not for SPRINT.
U can uninstall these settings from remove programs, and create new connections to access internet.
and do not use EPST folder if u novice to programming.
@ HP now start international support as well :support:
Its time for reliance to recognize us, and start paying ARUN for this solid support. BIG TIME MAN. :SI:
Edited by Shaikhsadik
Hello there
okay i just did that ..my question is should i just instal another SPRINT ROM or i ll be just fine with this?! is there is any similar interfaces you guyz aware off that would be SPRINT compatible and have the same look i really love this interface..thank you
CHeck forums for sprint man..!
My ROM is basically made using Reliance Settings to Run Vision of Sprint on your Phone
use Sprint Extended ROM Pack and Reinstall the Required Cabs
The Extended ROM Individual Pack can be found at PPCGeeks.com
Hetal, Can we have a cab file of all the software in this ROM separately, I updated to your ROM, but restored my software and data using SPB backup, so all your software vanished :Equivocado: , it was indeed a great package, but I cant afford losing the ones I presently have and dont have the patience of reinstalling them.
  hetaldp said:
Hetals AKU 3.5.4.B with New Core 2.6 with Sprint Radio Rom 1.27
AKU 3.5.4.B file is as Below
Hetal-AKU3.5.4.B=02-Jul-2007.rar Size: 62 Mb
Extended ROM for Reliance and Registry Setting is Below
Hetal-AKU3.5.4.B-ExROM=02-Jul-2007.rar Size: 5 MB
Currently i am buliding AKU 3.5 OS with 2.6 core, it have
  1. ArcSoft MMS Preconfigured with Reliance Setting (Atlast Incomming MMS with Picture is Working Perfectly)
  2. spb Mobile Shell 1.5 (Pre-Activated)
  3. Megasoft PocketCalc (Advance and Scientific Calculator)
  4. AtekSoft CoolCamera 1.13 (Pre-Activated), CoolCapture 1.13 (Pre-Activated)
  5. skb Group SMS (Activate it)
  6. SMS Reply (Free)
  7. RJV SMS Scheduler 1.0 (Free)
  8. WM5 Storage 1.75
  9. XCPU Scalar (Ready Made Tunning Just make it start on everyboot)
  10. Adore Reader
  11. Resco Explorer 2007 6.1
  12. PIM Backup
  13. Jeyo SMS Backup
  14. Call Blocker (Free)
  15. Bluetooth Browsing of Other PC (BT-FTP-Out)
  16. Allows Inbound Bluetooth (BT-FTP-In)
  17. New Dialer Skin
  18. New Contact Manager, Save Conacts from SMS and Call History and sort by Name and Surname
  19. MobiBook Reader 5.2
  20. HTC rZip
  21. SIP Change
  22. Better A2DP Support with Software on/off Switch
  23. Sd Card Removal Notification
  24. HTC Touch Audio Player
  25. Optional Bluetooth Printer / FTp / Browser / Audio Gateway Support
  26. New Communication manager from HTC Touch
  27. CyCle BT
  28. Bluetooth ON / OFF Button using Shortcut
  29. Remote Desktop
  30. Cybertron Voice Dialer
  31. PPC6700 Tweak
  32. O2 Running Program
  33. Toggle BT for ON / OFF of A2DP Profiles
  34. Total Commander
  35. psshutXP (For Rebooting PPC and Making Screen off Auto Reset phone on 7.00 AM everyday)
  36. Intent Midlet Manager (With Reduced Font Size)
  37. TCMPM 0.81 Player (Icon as PLayer)
  38. RegEditor PreInstalled
  39. WModem is Back
  40. Task Manager 2.7
  41. Microsoft OneNote 2007
  42. Windows Live (As i use it haha)
  43. HTC X-Button
Some Usefull Reg Hacks already madein Extended ROM
The Following file in Extended ROM is used to do the Reg Hacks
\Extended_ROM2\Rel_ExRom\HP_Rel_Settings.cab
  1. New Designed Reliance Boot Screen
  2. Reliance Extended ROM Screen
  3. PreInstalled Reliance MMS Setting
  4. PreInstalled Rel World Connection
  5. PreInstalled Rel NetConnect Connection
  6. PreInstalled Call Divert and Call Forward Setting Menu
  7. Customised Extended ROM
  8. Default.htm and Default_0409.htm have been placed as Default Home page for RWorld Shortcut in it.
  9. Notify me (SD Card Removal Notification)
  10. Camera Resolution Set to 1.3 Megapixel / Super Fine JPG with Store Directory as \Storage Card\My Documents\Camera
  11. Missed Call Alert / Reminder made on
  12. Owner set as HP-6700 (All Serial can work properly)
  13. Bluetooth / Ident set to PPC-6700
  14. Bluetooth by Default made ON (Dont Worry Dont conserve Battery)
  15. FlightMode by End Key made on so no Accedental Phone off by End key
  16. Word Suggetion Started after 2 Character in input Methods
  17. Save Sent Message made on
  18. Voice mail set to *600
  19. WModem made on for Multi-NAI
  20. MIP Error Made Hide no annoying error while connecting Rworld and RConnect
  21. Power Icon / Screen ICon kept Hidden (Power not needed, Screen Rotate No Accidental Pressing)
  22. by Default OBex (Object Exchange made) ON
  23. Delete Voice Mail Button Made on
  24. Screen Power Off on AC Supply made to = 10 Minutes from 30 Minutes (Video Watcher please remeber this)
  25. Clear Mype Made ON
  26. Glyph Cache for Icon have been Increased
  27. Menu Animation made OFF
  28. Extended ROM Mounted as \Extended_ROM2\ (Unlock it using Unlocker in EPST Program Group for Hacking
  29. Direct EPST / DM Router / FieldTrial Shortcuts so dont remeber that funny ## codes
  30. Extended ROMs Empty Space can used as Driver for Installtion or Storage. (Backup it before flashing in Future)
  31. R-World Icon in Program
  32. New Hetals Home Page for in Internet Explorer
  33. in All Alarm Set to 7am, 10am, 1.30pm Selected All Days and Kept the Alarm Off (So by mistake we cant forget to click the day)
  34. Intent Midlet Manager Font made small
  35. Time Zone for India have been Set
  36. Atek Soft Camera Resolution set to 1 Mega Pixel
  37. Atek Soft Default Save Directory made to \Storage Card\my Documents\My Pictures
  38. Left Key Set to SPB Menu
  39. Right Key Set to SPB Contact (Very Easy to Search any Contact)
  40. Automatically Reset the Phone every morning 7.00 AM using shutXP Software Youi can Reset this Timers
Added in Release B.
  1. BattV (Colorfull Battery Bar)
  2. *333 is Mapped to Speed Dial 3 (Now Press 3 and Hold it will dialer *333)
  3. Orange Today Screen
  4. Orange Color Dialer Sreen
  5. HTC Smart Dialing Ver 2.1
  6. Reliance Carrier Logo
  7. Call Firewall
  8. ## Codes now RUn Perfectly
  9. Red + Black Keyboard Skin,
  10. VicSoft VSnap 0.2 (Phone Screen Shot Software)
  11. Flashlite (Button 4 Press and Hold is Mapped to use Camera FLash Lite as Torch) (Logical Button 4 means Actual Buttong 3 on Left Side of Phone Marked as e)
  12. 25.5 MB Free in ROM and 8 MB Free in Extended ROM (For add on Softwares)
Hetals AKU 3.5.4.C with New Core 2.6 with Bell Mobility Radio Rom 1.41 released ! Please continue in this topic !
Guest
