sandeep bhandari
Rconnect On Vista ( Business Ultimate)
Hi Guys
Need your help .. soemdays back i bought HP Dv 6314 laptop having Vista Ultimate Business Edition but .. what makes me feel sad that i cannot install Rconnect Software ( LG Lsp 350 R) i need help from you guys on this ..
Thanks in advance .. if some one having solutions please reply
And if your are from INDIA .. DROP ME YOUR CONTACT NO .. IF POSSIBLE
Regards
Sandeep
Right-click on the setup file and enable "Compatibility Mode" in "Compatibility" tab. It should start the setup. :Equivocado:
Right-click on the setup file and enable "Compatibility Mode" in "Compatibility" tab. It should start the setup. :Riendo:
hi vishal,
I had purchased a laptop hp pavillion dv 6314 tx, which is having windows viesta ultimate 64 bit OS. I need to install a reliance net connect USB card (EC325 from Huawie India) for internet connection. But the driver for the same is not available neither with Reliance web worldd nor with HP fellows. This is a problem since 4 months.
The driver available on reliance website is compatible for 32 bit version OS, not with 64 bit.
If u r having some clue abt it, plz let me know.
thanks & regards
yatin agrawal
hi vishal,
thanks & regards
yatin agrawal
I have installed the HUAWEI setup but when i insert the net connect card in the USB port, it asks for a driver.
yatin
