vijaybavishi 0 Report post Posted January 25, 2004 Dear User of N191 samsung N191 samsung is having unique problem is that while saving incoming number from sms and voice call. When you save Number from Incoming sms and voice call you require edit the call to remove extra code of sdca and remaing. Now this edit facility while saving number is not available, so we have to write manually and reenter the number this is very problematic matter. Hope they will solve this in new version number. Thanks B.Vijay Kumar M Share this post Link to post Share on other sites
Arun 795 Report post Posted January 25, 2004 I guess you are conveying something like this... The incoming number is shown as 009198xxxxxxx (international format) and you want to put it like 98xxxxxxxx when saving the number to your phone book. If thats what you mean, then, it is not a problem as the charge for call/sms when you use the international format is the same as when you use the local format. Also, only if u save it in international number format, the name that you saved will be shown in the display when receiving call/sms. This happens for most GSM numbers. Happens for LG handsets too. Share this post Link to post Share on other sites
Chirag 5 Report post Posted January 25, 2004 Well Arun, What i have mostly noticed is that if u have a number saved in international format (009198****) and if ur phone doesn't have a STD facility, mostly u get error msgs frm Reliance that "this facility is not available on your phone". To overcome this problem i've seen some ppl save all three types of a no. in one NAME Entry. Like saving the Local,National as well as International Format in one Entry itself!! such that u can call on local format, get an incoming call on national format and an sms in international format!! That largely is tiresome to do. But its better than finding whose SMS it is! Share this post Link to post Share on other sites
vijaybavishi 0 Report post Posted January 26, 2004 Dear Sir Unlike LG and Samsung the Nokia handset is having facility to save number from Incoming voice mail and sms to have edit facility. This issue i have raise number of times with respective manufacturer but they not responding the same. I want Co-ordinator to raise with appropriate authority in customercare@reliance info.com so all customer can get proper justice. Thanks B.VijayKumar Share this post Link to post Share on other sites
Chirag 5 Report post Posted January 30, 2004 as far as i know, i've been able to save nos. from an incoming SMS on my LG handset! Share this post Link to post Share on other sites
anujit 0 Report post Posted March 10, 2004 I have used both the N191 & A563 handsets. I have set my numbers in international format (both mobile & landlines). I have STD & ISD enabled (who wouldnt considering activation is FREE!!!). Caller ID works great for me - for incoming calls & messages. This however doesnt work on LG handsets where you need to store 2 sets of numbers. Occasionally I find that the number resolution in my call history/sms stored messages has screwed up, a quick reboot (switching the phone off then on) fixes that. for some reason or the other sms name resolution doesnt work for rim phones when you have the data cable plugged in! i.e. when you are on the internet via the data cable - the sms inbox displays the RIM numbers not the persons name. when you disconnect it once again displays the persons name Share this post Link to post Share on other sites
Shabz 8 Report post Posted March 28, 2004 while reading SMS press call button it shows option to save Share this post Link to post Share on other sites
sun_capri 0 Report post Posted April 2, 2004 ye su r right, we may have to be PREPARED to miss out on PREPAID facilities I had confirmed it from WW the prepaid number cant be changed, even on paying Rs100/-, might somebody have given wrong information,, also the thing is it a GR8 hell using MOTOROLA handset. the problem with the h/s is >>>Very low ring tone volume... u cant hear it if u sitting in another room. or even if u sitting tight with in ur pocket. >> another problem with the h/s is very small characters..ots very diffucult to see even with glasses.. Share this post Link to post Share on other sites
sun_capri 0 Report post Posted April 2, 2004 Users N191 samsung i faced a very peculiar problem with N191 samsung while saving number from phone directory. When you shift the number from one location to another in ur phone book. and delete it from old location, it doesnt saves teh number and says that Number aleady in memory. now u cant save the number either doing a little change, e.g adding some extra character after the number. if anybody faced such type of problem please let know .. is this a s/w issue Share this post Link to post Share on other sites
Chirag 5 Report post Posted April 2, 2004 ye su r right, we may have to be PREPARED to miss out on PREPAID facilities....... also the thing is it a GR8 hell using MOTOROLA handset. the problem with the h/s....... Sun, do u realise, where u r posting wht?? :'( jus keep a check on that. and in case u think the post u made was not proper, feel free to use the delete button next to ur post and delete it. And in case u dont know wht to do, post the moderator and ask him to help u out! As far as wht Capri mentioned in his last post, i saw this glitch in my sister's handset. Wht i did to avoid this was to change the entry no. of the stored mobile no. That solved the problem. But the problem is truly severe. Can someone tell me the latest s/w no. for Samsung N191? Share this post Link to post Share on other sites
harsh_gupta 0 Report post Posted April 3, 2004 Users N191 samsungi faced a very peculiar problem with N191 samsung while saving number from phone directory. When you shift the number from one location to another in ur phone book. and delete it from old location, it doesnt saves teh number and says that Number aleady in memory. now u cant save the number either doing a little change, e.g adding some extra character after the number. if anybody faced such type of problem please let know .. is this a s/w issue Hi evbody ! I too faced exactly the same problem ... after changing the "group" of the number at the same location ( like from 'Fax' to 'Mobile' ), and then deleting it ! Now that no. cant be saved anywhere in the phonebook as it already exists at some mysterious location .... nor is the caller recognised. Cant even associate a Unique Ringtone to that no. I went to the Samsung Service Centre day b4 yesterday ... and the technican there wasn't willing to accept that it is the fault of handset . He was hard pressed to format/reset the phonebook and gave me a print out of the phone book .. wanting me to manually enter the 250 nos again After spending nearly 3 hrs at the service centre .. trying to make him understand that THERE IS some fault with the ROM ( .. i.e. the memory hardware ) of the handset or some other circuitry ..... he just agreed to keep it for a couple of days ... to look into the problem and trying to UNDERSTAND it !! Now have to go today to get back the handset ...... lets see wht the techie guys says !! If anybody got the problem solved please reply ASAP .... my warranty expiring on 7th of this month! Harsh Share this post Link to post Share on other sites
sun_capri 0 Report post Posted May 12, 2004 Harsh, yes this is exactly the problem , we all are facing , and what reply you get from SAMSUNG service station. do tell us. Chirag dont be oversmart by putting personal remarks.. Even after giving ur EXTRA SMART personal remarks , u have also moved to the topic i started. DARE NOT TO ACT SMART.. Moderator or Administrator can answer me for that. not you DEAR Share this post Link to post Share on other sites
Chirag 5 Report post Posted May 12, 2004 Chirag dont be oversmart by putting personal remarks..Even after giving ur EXTRA SMART personal remarks , u have also moved to the topic i started. DARE NOT TO ACT SMART.. Moderator or Administrator can answer me for that. not you DEAR Absolutely confused once again with ur post! Two things - Check out ur posts above(sun_capri Posted on Apr 2 2004, 05:23 PM) A Post regarding Motorolla in the Samsung Thread? Wht is it doin there? Thts wht i pointed out.. was there something wrong in it? And secondly, is anybody questioning me whether am a moderator or not? Dont feel offended dude(I know where u hail from), But theres nothing wrong in standing corrected! And Harsh, i too wanna know wht conclusion did the service centre guys finally reached to? Are any updates to Samsung N191 released? Share this post Link to post Share on other sites
harsh_gupta 0 Report post Posted May 12, 2004 Hi guys !! Sorry for not updating u all for so long ! Got busy with some stuff. So the story continues ... When i went to pick up the cell from the Service Centre, the technician (if at all he was one !! ) with whom i discussed the whole problem didnt even bother to come out n talk to me ... even when i insisted ... maybe coz he was afraid that he wont be able to convince me of wht he did ...... as expected ... he just reformatted the phone book ... that means the entire memory of phone including ringtones n my inbox full with SMS ... and again loaded the old phone book entries back again. Though it is working .... but this isnt the complete eradication of the problem. If I wud repeat the same sequence of events .. the same problem wud crop up again !! I've accepted that nothing can be done other than just waiting for the right oppertunity to upgrade the cell (RIM ppl .. r u hearing ??? ) Also, one news .. which will shake u all ... the service centre ppl used 200 mins of Internet from my phone and over 30 mins of local calls n unknown mins of R-world (got to know that from the video links in favourites in R-world) ) ... f**k them!!! Talked with the manager there .. he's willing to pay ... I've to go to him with the bill in a couple of days .. so will again update u ppl if i get the refund Since I'm a DAPO customer... my bill shot up by 500 bucks coz of their stupidity ... my calls were charged @ Rs.1.9 instead of Rs.0.40 .. coz those a**h**es used my mins in Internet. Never expected this **** out of these ppl ! N bout updates to SCH N191 .. no idea guys ! Till then ! remain immersed in the joy of RIM ! Harsh Share this post Link to post Share on other sites
anujit 0 Report post Posted May 12, 2004 Let me understand your problem correctly - you are trying to change the number type of a particular person from say HOME to MOBILE - when you delete the number from HOME & add it to MOBILE it says number already exists. I hope my understanding is correct. It will say that because the number is written to your memory only when you SAVE a entry! So your solution is fairly simple - delete the HOME number. SAVE - the entry. Open the entry again edit the MOBILE number. Save again. Viola you're done. Share this post Link to post Share on other sites
harsh_gupta 0 Report post Posted May 12, 2004 Let me understand your problem correctly - you are trying to change the number type of a particular person from say HOME to MOBILE - when you delete the number from HOME & add it to MOBILE it says number already exists. I hope my understanding is correct.It will say that because the number is written to your memory only when you SAVE a entry! So your solution is fairly simple - delete the HOME number. SAVE - the entry. Open the entry again edit the MOBILE number. Save again. Viola you're done. naaah ... probably if that's the solution u have to offer .. then u havent followed the problem !! Pls go thru the problem description again ... i dont have the stamina to explain it again Harsh Share this post Link to post Share on other sites
rim-matrix 0 Report post Posted September 23, 2004 hi ppl, i noticed that when ever some one calls the name of that person might not appear on the screen if the number calling is coming in a different format for e.g: if i saved "rahul" as 989201234 and when rahul calls in and the number appears as 0091989201234, the name will not appear!! But in nokia handsets this is not the case, they do appear even if the caling number appears in a diff format. any solutions to this problem?? Share this post Link to post Share on other sites
Ashokjp 15 Report post Posted September 23, 2004 This is nt any recent bug, it was the same with these handsets earlier it self.. The only way out is save the no's in both format for that name like in 009198.. format and 098... Share this post Link to post Share on other sites
raccoon 53 Report post Posted September 23, 2004 Its really sad that they still haven't done anything to resolve this irritating bug! Can someone tell me if the Moonlight and the new colour phone have the same problem? Share this post Link to post Share on other sites
Saurav 22 Report post Posted September 25, 2004 Yes its actually a problem in reliance servers nt in handset. Share this post Link to post Share on other sites
karpar 1 Report post Posted September 25, 2004 Then how come the nos. are displayed properly in the Nokia sets??? Share this post Link to post Share on other sites
Vishal Gupta 4 Report post Posted September 25, 2004 Problem with handset not with server! Share this post Link to post Share on other sites
ami114 0 Report post Posted October 11, 2004 Problem with handset not with server! 14490[/snapback] when got any solution then pls tell me also Share this post Link to post Share on other sites
Ashokjp 15 Report post Posted October 22, 2004 It doesnt have anything to do with Reliance servers.. Share this post Link to post Share on other sites
