mohit_ayush
How To Connect Lg Rd 6330 With Computer
I had purchased lg rd 6330 phone .now I want to transfer my videos and pictures that I had taken to my computer.How shall I proceed Which data cable should I use and which software should I use and how to install that software
you can find th software on lg website. abt the datacable, you can visit the local lg service center and ww for details.
:Riendo:
Steps in Connecting LG 6330 to Computer with USB cable and Browse Web in your PC
1. Buy good USB cable
2. connect cable's one end to Mobile and keep it ready
{Set Phone's Menu>Setting>phone>datasetting>Databaud>USB for LG6330/6500}
3. Run CD; when instructed, connect the cable's another end to PC's USB port [select USB when among USB or Serial]
[Download Driver from http://www.reliancecommunications.co.in/Co...s_lgrd6330.html for LG6330)
or http://www.lgmobiles.com/index_cdma.php > select PCsync >6330.
4. Now cable is installed itself , then modem of phone is also automatically installed by the same software
{ Ensure at PC's Control Panel>Modem>Prop>Diogn>Query modem}
5. Enter Your Reliance Phone number without STD code or Zero In both 'User Name and Password'; then click Connect in RConnect Dialer
Now Browse Web from your PC :Riendo:
:GirandoOjos: 6. Use "HELP', when faced any problem to correct it in RConnect Dialer
4. Download LG SYn file and instal in your PC
[ http://www.lgmobiles.com/RD6330_SYNC_20060311_1_UAT.zip for 6330 ]
5. open LG Desktop in your Desktop
6. GO to Syn confg for options, then GO to Syn
7. See that Phone to PC or PC to Phone data[Address to outlook etc, TO do, Picture, video, Sound etc] transfers
8. Your can also down load the Net Booster to speed up browsing from above Reliance web site
http://www.reliancecommunications.co.in/Co...netbooster.html
:winko:
That's all to enjoy to browse at pc and transfer between phone and pc
<<<Redo the above Phone/Cable/Syn if faced any problem after some time>>>
Enjoy
But I Could not open LG6330's *.mjp and *.qcp[audio] files in windows xp
Can anybody help to convert MJP/QCP files to use them in Windows XP
Edited by asokan_m@hotmail.com
