Shabz
Samsung Code
In samsung n191 go to menu + 4 + 0 you will find TTY/TDD LOCK and it asks for a code I tried for several combinations but could not get thru it till now has anybody tried this thing please see
Edited by shabbooo
Dunno - anyone knows the key combiation for LG RD 7130 ? (if that info is OK to post on this board)
it is a four digit code which i am talking about
Try some cominations like 0000 or 1234 ;)
:( dont try the combinations u r h/s may go useless. B) as it is entered by reliance while burning r-world in h/s software... ;) i am trying to learn how they make up these codes
well I got the reply to my query the code is #TTY ie #889 but I do not know what this does it has somthing to do with handsfree try it
In samsung n191 go to ment + 4 + 0 you will find  TTY/TDD LOCK and it asks for a code I tried for several combinations but could not get thru it till now has anybody tried this thing please see
7461[/snapback]
Goto the menu --> 7. Security :- It will ask for code, if you have configured code for this then enter it, and if not refer the manual. Same code you enter to the above issue.
Regards
Grafix Guru
guru_anaga@hotmail.com
I have got the code and have written it up the code you r talking about is the security cide
HI all
Samsung sch-n 356
i got spc code !
but i dont know NAM programming mode (keypad combinations)
Anybody know ???
PS
i don't need any security informations!!!
i need only keypad combination!
other ...(spc and other i know well)
Edited by cdma_pmr
no grafix guru both the codes r not same default security code is 0000 and the tty ttd code is #889 hope u have ssen this on you phone I found this code at some site which I do not remember now I had gone on that site from some link on rimweb but that link and the post has been deleted now :o
