Sadikk
Now Its Time For 3 Sim Phone, Yes U Heard It Right :)
Hello
Guys soon i will be offering 3 SIM phone :lol:;) ;) ( They are planning to launch dual till now ) :NOTriste::GirandoOjos::D
Anyways phone can be use with CDMA+CDMA+GSM OR GSM+GSM+CDMA. ( i.e TATA+RELIANCE+HUTCH or AIRTEL+HUTCH+RELIANCE )
2 models will be available, whichever u use.
Best part of these are its QUAD band means u can take ur number any where in the world and get un-beatable roaming advantage.
Let me know if it will work in india. and how sure i shud be about its success.
Get me businesses and see unique gadgets coming :D
seeking for some serious queries and replies.
IDEAS are always welcome @ shaikhsadik@gmail.com
As these handsets are not from known Brands, so price should be nominal below 10K. Spending more than 10K for handset with no ASC is not feasible as in case of GTRAN.
whats d benifit yaar of 3 sims....
u ever saw a person holding 3 mobiles in hand??
sadik bhai ki jai ho...
well i now have three phones with me for past one month. one reliance and one airtel and 1 BSNL and at times i have Reliance FWP Cordless with me too coz of free RIM calling
^^^^ Do u own a Pc Booth :lol: (Joking man)
not phone both..... MOBILE CALLING STATION.
Wow...3 sims at one time :rolleyes: But i was thinking, what will be the amount of radiation being subjected to the person holding a 3 sim phone- will it be equal to talking with 3 mobile phones at the same time? :unsure:
of course not!
the radiation comes from the type of handsets not the SIM.
* flip phones minimise exposure (angled away from your head) and bar phones maximise it.
* the angle at which you hold the handset makes a big difference.
* if the phone is switched off it has zero radiation while its max during use/talking (standby is in between and varies depending on distance from the nearest tower)
* using a headset reduces the exposure you would get to that on a bright sunny day at high altitude which is nominal
* the intensity falls off exponentially with the cube of the distance since its a volumetric measure
* if you use your handset for < 1-2 hours daily, there is no measurable impact in multiple international studies
* TV has almost 1/4th the intensity and PC monitors about 1/3rd that of a mobile (since PCs are usually much closer)
* analog handsets had 3-4 times the intensity of digital phones (99% of those in use)
don't focus on absolute risk as it is irrational
relative risk is much more important and relevant:
you are far more likely to die travelling by bus, train, auto etc than due to your mobile's radiation
does that mean that you will never leave home?
Thanks for the explanation city02. ;) My concern was does these 3 sim phones use three individual RF transreceivers for operation? It has to be three separate once else how to sustain all networks simultaneously? Is it this way?
